Hi all
this is my second attempt to spec a a quiet and energy efficient i5 based system, the first was just more than I can afford at the moment! I'm going to be using the system for some gaming (aiming for basic playable frame rates) and 3d rendering. I won't be overclocking. When cash allows, I'll probably add another 4GBs of DDR3 and upgrade the graphics. Anyway, I'd really appreciate comments and suggestions on the components (especially as some are definitely in the budget area).
Many thanks again (and sorry for asking for comments yet again!)
processor
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail £149.99
http://www.overclockers.co.uk/showproduct.php?prodid=CP-299-IN
graphics
XFX ATI Radeon HD 5750 512MB GDDR5 PCI-Express Graphics Card £88.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-155-XF
motherboard
Gigabyte GA-P55-US3L Intel P55 (Socket 1156) DDR3 Motherboard £80.99
http://www.overclockers.co.uk/showproduct.php?prodid=MB-207-GI
memory
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Low-Voltage Dual Channel (OCZ3G1333LV4GK) £71.51
http://www.overclockers.co.uk/showproduct.php?prodid=MY-183-OC
power
Corsair VX 550W ATX Power Supply (CMPSU-550VXUK) £68.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-CS
hard drive
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £39.99
http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA
case
Coolermaster Elite 335 Case £31.67
http://www.overclockers.co.uk/showproduct.php?prodid=CA-160-CM
optical drive
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - OEM £18.99
http://www.overclockers.co.uk/showproduct.php?prodid=CD-090-LG
Total : £564.33
(and win7 64bit)
processor
graphics
motherboard
memory
power
hard drive
case
optical drive
Total : £564.33
(and win7 64bit)
