Im watching a review on the Cooler Master 690 II and i noticed it had a vertical PCI expansion slot next to the horizontal ones. What is the vertical one used for?
I would say for using breakout cards, such as USB headers, fan controls, an additional daughter card to the soundcard etc. Means it doesnt block off an expansion slot you may need.
ah that makes sense. So its cards that need a expansion slot but doesnt need to be in a PCI slot? but if you have a wide graphics card the slot will be useless...
