thermalright SI-128 SEsmall good cooler plsssss
cant fit a fenrir too highis there any smallish cpu coolers that are as good
8 hours, 19 minutes. prime95 on blend , ram timings 8-8-8-20 2t
yes ultra-120AI am wondering about your cooling Gareth, I did skim the thread but I didn't see it, I think you said before you had a Ultra-120 classic right?
one side my case isn't on fully due to the cpu cooler touching the 38cm side fan. so i guess that helps abit. from about 5-6pm my room temp drops so tomorrow i may try..If you freeze your system down a bit (open windows etc) and confirm it's happier at 4.0GHz then maybe there is scope to get you some enhanced cooling sorted . . .what do you think?![]()
Martini1991, what voltage u using for 2.8ghz NB?
ok your cpu-nb is slightly better then, mine needs about 1.35-1.375v... for 2.6ghz it needs 1.275v so im keeping at that for now..1.3V
In general the CPU NB clock should be at least three times the Memory clock
(example in case of DDR3-1600: 3 x 800MHz = 2400MHz NB clock)
CPU-NB voltageHi, are you changing the NB voltage, or the CPU-NB voltage ?
what ram u using?, id be very happy to get mine to 3.8ghz with 1.4 voltage, and with 2.6 ghz NB.
what ram u using?
if its 1600 then the minimum nb frequency should be 2.4ghz or higher.
i don't think a new bios update will fix it tbh, i can't even get my ram stable at 7-7-7-20 1.7v which is stock, but it need 1.75v to get 90% stable and 1.8v for 100% stable. but im not happy with keeping it at 1.8v.PC3-12800C7 1600MHz 7-7-7-24, but the Asus M4A79XTD can only run it at 8-7-7-24, unless they fix it in a new bios update.
what ram u using?
its CPU clock on default 3.4ghz, auto cpu voltage, i set NB freq to 2.6 and changed CPU-NB voltage to 1.26 and it crashed why is that ? ram running at 1600mhz
