Outputting WDHDTV to Component or VGA??
31 Oct 2005
Leeds
Hi there,
Been using the WD HD TV thingymabob too put my Harddrive items through my old standard def TV
After upgrading the downstairs set I now have a 28inch Samsung HD upstairs, now this HD tv does NOT have HDMI
Therefore wondering a few points
1. Can I cheaply buy a HDMI to VGA / Component cable?
2. Should I go VGA or component?
3. I have no HD media on the device, will I actually notice any image quality rise? i.e upscaling etc...
1. HDMI is digital, VGA + Component are both analog signals. You would need a middle-man to convert the signal, which might add a fair bit of expense.
2. The WDTV doesn't have a VGA port? At least my WDTV doesn't. Component will be fine for movies that aren't in HD.
3. It should be fine, I've played HD + SD movies through a SD TV, and they both look great through a 9 year old TV.
cheers for the reply
just to clarify, the WD has a HDMI out socket, I'm planning on using that socket, but rather in it ending in a HDMI socket, I was hoping with component or VGA.
As you say it looks like I would need a middle man signal convertor, what about DVI?
You can get HDMI > DVI converters very cheap. I know, because I have one :)
You'd need to do the sound through the optical though, as DVI cannot do audio.
..and component will also be fine for HD, all the way up to 1080p :)
Composite is the bad SD one.
