Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I've done a few for clients when i was working in an Architct Practice.
First, you need to get yourself a piece of land, or have a piece of land in mind.
If you have the land, then you can apply for planning permissiong. If not then you can always apply for planning permission, or even outline planning permission (cheaper in terms of architect costs as the drawings are much less detailed), and then once you get it, then buy the land. You do not need to own the land to apply planning for it, but you do need to serve notice on the land owner, the down side to that is if planning is granted on a piece of land that did not have planning for a build before, the value of it immediate goes up. Any land that already comes with planning will cost more than the piece of land next to it without planning. So it is a catch 22 situation, the way to "guess" if you can get planning is take a look at the surrounding area, are there any simialr new build happened there in the past few years? and you can always take some photos of the land, take it to the local planning office and speak to a planning officer and have an informal chat about your prospect of sucess of getting planning.
The other way is to buy a house with a large piece of land attached, preferably on the side of the house is a large garden. Apply for planning on the garden and split the land in half, sell the old house, a guy i worked with did just that.
So, once you have decided on the land you want, go speak to an architect. Have a brief in mind, the number of rooms, materials used, want underfloor heating, style of design etc. Then basically you can leave it all up to him, just make sure you budget well, as costs WILL escalate. Budget for the land, and then budget for about £1,200 per meter square and you are about right, then add 5% for contigency.
The whole process is a lot more detailed so good luck.
p.s. In 2 and a half years i never had a planning application rejected, kinda proud of that record
