- 5 Apr 2008
Hi, I have an overclocked i7 (3.9ghz) and 2 5850s on a waterloop with a black ice gtx triple radiator.
I have it mounted at the top of the case internally, with 3 gentle typhoon fans drawing in air from the top (outside). I have not put an exhaust fan on the back (I probably should
Now... The air inside the case is really quite hot. From the radiator. I have the side off at the moment or it would overheat in there. This heat makes the room very hot so the water struggles to keep kwl. I have got the window open!!
Here is the question...
What should i do, I can put a 140mm exhaust on the haf (either included 140mm from coolermaster or another). That will still make the room very hot.
