- 5 Jun 2003
- sawley/ long eaton
most dont kick in if outside airtemp is below4-5c
Do any air con systems cut out when the Outside Air Temp reaches less than 4C? Or do they all (or the vast majority) cut out when the evaporator temp drops below 4C, enabling the system to continue to work if it is in re-cyc and the inside of the car has warmed up.
Summary: You most likely can use your air-con in this weather, just put it in re-cyc, turn the air-con on, set the temperature to something hot, then sit back and let it pump moisture out of the car.
( |-| |2 ][ $;15702512 said:You and Fox are both right there can be examples of damp in a car other than a leak.
Without getting into a full on argument can I say that the normal blowers should be able to handle that no problem? I've not had any steaming up issues during the cold weather..
How does it go out the car when you have it on recirculate?
How does what go out the car?
The wet air ? when you air restricting natural airflow by having the blower intake taking air from inside the cabin and not outside?
