Stand with your feet slightly shoulder width apart, and look down, the bar should cut your foot in half - that's what you should see, half your foot.
Don't bring your arms too wide, the wider apart your arms the higher you have to lift the bar. Your knees should slide along your forearms as you lift.
You should almost be scraping the bar up your shins.
Bend down more! Your legs are almost straight, you should almost be in a squat position.
Push with your heels - do not pull the bar up, I could see you pushing through your toes a bit. You should almost be falling over backwards were it not for the bar.
COMPLETELY unload the bar between each rep. Especially important as you get heavier as you may need to readjust grip, and re-evaluate form, foot position etc...
Your back should stay straighter, try and keep your lower back neutral and your shoulders back.
As you get to the 2/3rd point of the lift, push your hips forward.
Even though I made lots of comments, they are not criticisms, as in general the form is good.
It just needs a bit of fine tuning.
Try not to use gloves if you can avoid it, it won't help your grip development, I used to use gloves and tried to deadlift without them, could hardly hold onto 120kg. Fortunately now without gloves or straps I can do considerably more.
