5970 + gigabyte ud7
3 Aug 2008
Bath, England
hi all,
i'm having problems, as in i think i need to RMA my gpu; but i just wanted to check if anyone was running a 5970 on the ud7?
i literally just had the thought that it *might* need a bios update to get it to play ball.
what does everyone think? or if anyone has this combo, please let me know of their experiences :)
many thanks
I havnt got the 5970 but i do have the 5870 and it runs fine on my UD7 without doing any bios flashing.....what problems are you actually having?
Try pushing it up a bit then clamping it back in, my computer refused to boot until i did this as it's such a weighty card.
Can't see what a BIOS update would do tbh.
Can you try it in another machine?
unfortunately, none of my mates around here play pc games :/ bunch of boobs!
it won't post, does a beep code for gpu error, and the error light on the 5970 comes on when the pc is started
i'll give that a try, i've setup an rma with ocuk so if it is borked they can have a fiddle :)
very strange...
i didn't think of checking that code considering the card lights up claiming error as well as the beep codes. do you think there could be a possible conflict?
Could be, that code is from another board but most share the same debug codes across the range.
Anyway here's a linky.
http://www.xtremesystems.org/forums/showthread.php?t=218840
awesome, thanks a lot mate. i'll have a read now and see if i can try and figure it out.
have u tried the card in any of the other PCIe slots on the mobo or have an old card u can test with?
i've got my 2 4870's back in there at the moment, running in the 2 pci-e 16x slots, and they're working ok (apart from i'm getting savagely hot vram temps and display driver keeps crashing).
i've tried the 5970 in both of those slots too, and still nout...
