Dell Ultrasharp 30"
24 Nov 2009
Edinburgh, Scotland
Quick Question. The Dell Ultrasharp has two DVI-D ports, but how should it be set up if i had crossfired two cards with each one having two DVI-D ports? One plug in each? Or both the plugs slotted into one card? Cheers guys:D
with two crossfired cards, you would have a crossfire bridge between them, so they are already linked together. all you would need to do to plug your pc into your monitor would be to plug a dvi cable into one of the ports on your monitor and one of the ports on one of your graphics cards.
Ah right. I'm learning! Cheers.:)
