Colleagues,
Some excellent Patriot memory deals with more to follow.
*** *** Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (PVT36G1600ELK) @ £126.99 inc VAT *** ***
Patriot Extreme Performance (EP) Enhanced Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 9-9-9-24 timings and is available in 3GB and 6GB kit capacities. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Enhanced Latency (9-9-9-24)
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- 100% Tested and Verified
- Lifetime Warranty
- RoHS Compliant
- XMP Ready for Core?i7 Processors
- Tested and compatible with Intel? X58 Express Chipsets
Only £126.99 inc VAT.
ORDER NOW
*** *** Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel (PGV34G2000ELK) @ £115.98 inc VAT *** ***
The Patriot G Series 'Sector 5' edition is engineered to expand your gaming options for the Intel® P55 platform. Equipped with lightweight aluminum heat-dispersing shields these modules are engineered to run at 2000MHz with 9-9-9-24 timings, available in 4GB kit and comes with a lifetime warranty.
- Extreme Performance PC3-16000 (2000MHz)
- Enhanced Latency (9-9-9-27)
- XMP Ready
- Equipped with advance aluminum heat-dispersing shields
- Lifetime Warranty
- RoHS Compliant
- Tested on Intel® P55 chipset
Only £115.98 inc VAT.
ORDER NOW
*** *** Patriot Extreme Performance 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel (PVS34G1600LLK) @ £100.99 inc VAT *** ***
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 7-7-7-20 timings and is available in 4GB kit capacity. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Low Latency (7-7-7-20)
- Lifetime Warranty
- RoHS Compliant
- XMP Ready
- Tested and compatible with Intel P35 and X38 chipsets
Only £100.99 inc VAT.
ORDER NOW
*** *** Patrtiot G Series 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGS34G1333ELK) @ £79.99 inc VAT *** ***
Patriot Gamer Series (PGS), part of the Extreme Performance (EP) Enhanced Latency line is engineered to expand your gaming options. These modules are designed to operate at 1333MHz at 9-9-9-24 timings and is available in 4GB kit capacity. Equipped with lightweight aluminum heat-dispersing shields, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-10666 (1333MHz)
- Equipped with lightweight aluminum heat-dispersing shields
- Lifetime Warranty
- RoHS Compliant
- Tested on Intel?P45 and X48 chipsets
Only £79.99 inc VAT.
ORDER NOW
*** *** Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGV34G1333ELK) @ £79.99 inc VAT *** ***
The Patriot G Series 'Sector 5' edition, part of the Extreme Performance (EP) Enhanced Latency line, is engineered to expand your gaming options for the Intel® 5 platform. These parts are engineered for maximum performance and stability under extreme overclocking conditions. The G Series 'Sector 5' edition are built with quality and performance in mind and are the ultimate solution for extreme overclockers, gamers and PC enthusiasts. Equipped with lightweight aluminum heat-dispersing shields these modules are engineered to run at 1333MHz with 9-9-9-24 timings, available in 4GB kit and comes with a lifetime warranty.
- XMP Ready
- Lifetime Warranty
- RoHS Compliant
- Tested on Intel® 5 chipset
ORDER NOW
- Lifetime Warranty
- RoHS Compliant
ORDER NOW
- XMP Ready
- Lifetime Warranty
- RoHS Compliant
ORDER NOW
- Lifetime Warranty
- RoHS Compliant
- XMP Ready
ORDER NOW
- Lifetime Warranty
- RoHS Compliant
ORDER NOW
- XMP Ready
- Lifetime Warranty
- RoHS Compliant
ORDER NOW
