Free o&o Pro 10
Hello there! We are delighted that you are using our O&O Defrag program. Unfortunately, your version is out-of-date. We would like to introduce you to the new version 12 of O&O Defrag, available to you at a very special price - but only for 48 hours!
You can upgrade to the brand new version for just US$ 14.95 instead of the usual US$ 29.95! You save a huge 50%! But hurry - the offer is only valid until the 14th January, 2010!
Buy now in our Online Shop!
New features of O&O Defrag 12 Pro at a glance
NEW: Fully compatible with Microsoft Windows 7, Vista and XP
NEW: Improved overall performance
NEW: Zone filing for optimal organization of files
NEW: Three additional defragmentation methods (eight methods in all)
IMPROVED: Once again up to 50% less memory burden
IMPROVED: Once again up to 50% faster defragmentation
Automatic configuration after installation - no intervention necessary!
Extensive defragmentation of system files possible (Meta files)
Numerous detailed improvements
Fragmented hard drives slow down your PC - fact!
After installation O&O Defrag 12 Pro works constantly in the background, analyzing the degree of file fragmentation, whilst at the same time preserving resources.
Whenever O&O Defrag 12 Pro finds files which have been saved fragmented on the hard disk, it remembers them. As soon as these files have not been accessed for some time, O&O Defrag 12 Pro automatically begins defragmenting them.
Less than 48 hours after installing O&O Defrag 12 Pro, your computer has already been optimized - thanks to the automatic background monitor and the consequent defragmentation!
O&O Defrag 12 Pro, however, goes one step further. All your system's files will be sorted according to their level of use, and each one will be separated into its own section of the hard disk (drive zones). O&O Defrag 12 Pro introduces 3 new defragmentation methods that can also apply a user-defined classification of files to perfectly complement all previous methods.
Buy the upgrade of O&O Defrag 12 Pro for just US$ 14.95 instead of US$ 29.95 directly in our online shop and save 50%.
Best regards from Berlin, Germany
Jim Harrison
Director of Sales International, O&O Software
PS: This offer is valid until 14th January, 2010 and available exclusively to you as a registered O&O customer!
Good price for the upgrade but does that mean you always have to install v10 then upgrade to v12 in the same way Windows works?
oh no. you're falling for their evil plan. just use the old version. free is a much better price. i can't really see the point in spending money on a defragger.
I used the free V10 on my works laptop and there was a noticable difference applications like Lotus Notes and Sametime were much improved with less lag when using them.
Might try the free V10 on win 7 at home as someone mentioned above it works.
It's been renamed to MyDefrag now and is much simpler to use.
I didn't realise until someone told me in another thread a while ago :o.
I'm still using JKDefrag here, MyDefrag is virtually the same, the only noticeable difference being the addition of scripts to ease defragmenting for novices.
Thanks for O&O Defrag, I find it's background defragmentation option useful for server environments.
