The latest version of this great program!
Dear All
Afterburner 1.5.0 Beta 4 is finally here!!we have many localization language in this version, please have a check if you can read those non-English language! thank you all!
By the way, we have very big and pretty furry surprise coming soon in Afterburner functionality. Stay tuned!
Download:http://event.msi.com/vga/afterburner/images/MSIAfterburnerSetup150Beta4.zip
Changelog
- Added localization reference guide manual for localization creators
- Added built-in localization debugger
- Added Dutch and Italian language packs (as usual, public proofreading is greatly wanted).
- Now voltage control is also locked by default in safety options in advanced
MSI Afterburner properties
- Added AccessibilityCheckingPeriod configuration file switch for improving the
compatibility with AMD ULPS power saving technology on Crossfire systems. The
switch allows low-level monitoring module to use AMD driver API to check GPU
accessibility and detect and display GPU sleep state properly. Please take a
note that AMD API implementation is ineffective and hardly suits to realtime
monitoring due to high CPU stress resulting in periodic stuttering in games.
That is why the compatibility switch is disabled by default, enable it only
if you absolutely need to see slave GPU sleep state on the graphs and accept
side effects like performance drop and stuttering resulting from ineffective
- Added NVIDIA GT240M PCI DeviceID range to the core to provide more efficient
hardware monitoring via low-level core on mobile NVIDIA GT240 based systems
(bonus feature, official mobile systems support is still not declared)
- Graph limits are now adjustable in the graph properties in <Monitoring> tab
- Added AMD RV810 graphics processors family supports
- Added voltage control for custom design MSI R5670 1GB series graphics cards
with uP6262 voltage regulators
