Ya think?284ml (half pint) at 2.5% = 0.7 units, or 0.7cl of alcohol, if it being marketed as 0.5 then it is a lie.
A drink with 7ml alcohol will measure at 0.5unit (yay marketing!). Three of those and you're at 1.5units, huzzah.. oh wait, no, you're at 2.1! Change it to 0.7cl (or 7ml) and you've got a more accurate measurement.![]()
True.. but why not just use a more easily recognisable measurement, such as centiliters/millimeters?
I'm fairly sure that is only occasionally true, in fact I have a bottle here now labeled as 3.4 Units - so it's likely down to manufacturers rounding rather than a fault of the system.
If anything I expect it would confuse people more. They might think their 500ml can of lager is very weak, only having 20ml of alcohol in it, when they previously assumed it had 500ml.
Ya think?![]()
I would go so far as to say most people don't understand what a unit is.
So clamp down on alcohol producers lying about the alcohol content of their products?![]()
Of course it's not but providing information is useless if people don't understand it, whether they notice it is a different discussion.Our culture of drinking is not going to be fixed by changing what we call things.
I bet if you asked the public, very few could tell you what a unit was in ml
Do you think most people can really visualise 2cl of alcohol and know how drunk it is going to make them?
No, because the limit would be a straight number of 2cl. If you drink more than 2cl you're over the limit. Doesn't matter how much you wash it down with. You could drink a swimming pool with only 20ml alcohol in it, but that's put you at the limit.
I realise it works exactly the same as units, but the simple point is that there are *so* many people who don't know how much a unit is.
Yes and no. Tell someone they mustn't be over 'x' at the time of breath test makes it very complicated. Tell them not to drink more than 'x' from the start is a lot more simple.Drink driving limit has little to do with how much an individual actually ingests though
Do you think most people can visualise how much 2 units is or how drunk it will make them?![]()
Yes and no. Tell someone they mustn't be over 'x' at the limit makes it very complicated. Tell them not to drink more than 'x' from the start is a lot more simple.
No, but it doesn't matter - they don't need to.
If you tell someone a drink is 2 units they aren't going to magically know what that means and how powerful it is, either.You don't need to know how much alcohol is in a unit - you only need to know how many units you can safely drink, or how many make you drunk (which varies from person to person, everyone finds their own limits).
If you tell someone a drink has 2cl of alcohol, they aren't going to magically know what that means and how powerful it is.
Of course it does do you not think sensible drinking should be encouraged, don't you think it's pointless providing information the majority do not understand.
One is a more recognised and understandable measurement, which is used on every daya packaging and is used in schools and well.. everywhere. The other is this magic number that depending on who you ask represents a different volume, and is much lesser known.And so what difference does it make whether you're telling them they can have 2 units or 2cl?
