- 11 Dec 2008
As an adviser, I can only echo what most others have said, however I would say in response to Kami that a ballpark figure of £1500 would be too low, and would suggest nearer £4000 would be better to cover all associated costs. Stamp duty would be 1% of the value of the transaction, so your looking at around £1500 just for that.
One question that I do have to ask is why the rush? If you can say the 10% in 6 months, why not wait a little while longer and save maybe 20%?
I have no idea of your current living situation, so I cannot say one way or another whether this would be fesible for you.
Joint applications usually work either one of two ways; either they take your combined salary and multiply it (i.e. x3.5), or they take the higher of the two salaries, multiply it (i.e x4.2) and add the lower of the salaries after the multiplication. Some lenders like Northern Rock allow you to choose either, so you should work out which method would allow you to borrow the amount you would want.
Do you have any idea what sort of credit rating you currently have? Since this can affect just how much the lender will times your salary by to give you what they are prepared to lend.
Dan
Dan
