Best Radeon HD 4870X2 Cooler
13 Jun 2008
Hey. I'm running a Radeon HD 4870x2 with the stock cooler, can anyone tell me what the best aftermarket coolers are for this card? I've seen the coolers but Artic Cooler and ASUS but I have no idea which one (or any other I've not seen) reduces temps the most.
Cheers!
You can only get the artic cooler version as its the same as the asus one so i would say if you want good temps on load the artic cooler is the way to go or watercooling
+1 for the Arctic Cooling!
Fitted one for a friend a few months back and its very impressive.
It's silent up to 50% fan speed and only just audible as you get higher but to be honest you can just set it at 50% and forget about it.
and it makes the length around a inch longer i have heard :(
Not sure where you heard that but at worst it might be an additional 1cm from the tips of the heatpipes.
