I'm upgrading my PC very soon but I can't decide what to go for! At first I was going to go with i5, then I heard about the socket problems which put me off, after that I was dead set on the PII 965 (125w version) but now I've been heavily swayed towards the i5 again. With the i5 I would buy a Gigabyte P55A-UD3R motherboard as they're supposed to be very good and definitely don't have the Foxconn sockets. If I were to go Phenom II I'd probably go a high end motherboard as well. Not sure exactly what I'd go for, probably a gigabyte of some description.
The i5 setup would generally cost me a bit more, about 60 quid more to be exact but the advantages of the i5 setup would be better performance and 2200mhz ram support (would be buying some 2000mhz sticks if I got the i5 setup) and the advantages of the PII setup would be proper support for crossfire and cost. Is it true that the i5 will overclock better though? I heard the 125w 965s were great for overclocking, but a friend on another forum has had lots of trouble reaching 4ghz with his and to get 4ghz he eventually had to change his chip for another one and buy a new motherboard.
Really confused as to what to go for at the moment! Help please
