Let us know how you fare with your first applicationMy Driclor has arrived, no more sweaty palms for me.
I've just bought some for my palms too. They are sweaty 100% of the time, praying this works.My Driclor has arrived, no more sweaty palms for me.
But hands though? Are you sure it's going to work? The skin on your hand is much thicker that the skin under youy pits.
Oh, I'll lather it on tonight I guess.It shouldn't take too long. When I used it on my pits the first time, I didn't sweat at all the next day, it was an instant (but painful) result!
Did it work for you the day after?Yeah it works.
Pretty much every antiperspirant on the market contains the same active ingredient just smaller amounts.Never even heard of this stuff before, I don't think I'd try it for the reasons mentioned already, just seems a bit wrong to be blocking stuff up like that. Scary stuff![]()
The active ingredient reacts with water to create an acid which causes the stinging sensation people report.How come you have to use it the night before?
I use Anhydrol Forte and while it itches, it's not too bad. No sweating in that area for 4-5 days too.
it is an essential part of your respiration system
I bet 99% of unwanted sweat (i.e while not exercising) is due to excessive weight and / or generally unfit.
Meh, my view is that you sweat for a reason, i.e it is an essential part of your respiration system to keep your body regulated well heat wise.
Sweat will only smell if stale, so as long as you wash daily and change your clothes I don't particularly see the need to fill my armpits with a metal that the scientific community can't decide is toxic or not......
I bet 99% of unwanted sweat (i.e while not exercising) is due to excessive weight and / or generally unfit. Sort the initial problem, not the body's natural solution.
