These apparently fix a L4d Xfire issue, and also supposedly give better performance in Dirt2
Dirt 2 performance boost - Is it crossfire related or just general ?
As far as im aware, they are the exact same drivers as the AMD set, just they support fewer cards, but they do support the 5970, which for some odd reason, the AMD ones don't.![]()
Absoloutely flying with none of the previous FPS halving problems.
Don't say that the 5870 lot will shoot you down its not possible![]()
Source ?
Source ?
hope so, will have to try out when I get back from work. Although I've decided to fix xfire issues by going single card.... oh wellThese apparently fix a L4d Xfire issue, and also supposedly give better performance in Dirt2
I got that years ago with a dodgy CCC install, just uninstall everything and try againAnyone else get this MOM.implementation failed to load error?
