- 18 Oct 2002
- Stone, Staffordshire
I had noticed, as I'm sure most of you did too, that in winter 2009 the motorway signs that used to say "Gritting in Progress" were changed to "Salt Spreading"
I decided to dispatch an e-mail to the Highways Agency and here is the response
And this was their reply:Dear Sir / Madam,
I would class myself as a motorway “Power user” and as such feel that I have observed a change in motorway sign notices and was wondering why there has been a change in terminology.
For as long as I remember the motorway road signs have read “Gritting in Progress” but since winter 2009 I noticed that these have changed to “Salt Spreading”. Whilst I appreciate that there is no grit actually involved in the process of protecting our highways I just wanted to understand the reason for the change in wording and whether there was more to it other than to better reflect what was actually being done?
I appreciate that you may be very busy with enquiries at the moment so there is no rush for a reply but I would appreciate a response when time allows.
Best wishes
Admiinistrator
www.windscreenwipers.org.uk
So there you go. The great mystery resolved!Dear Administrator.
Thank you for your e-mail to the Highways Agency Information Line of 07/01/2010 in which you raise the following issue;
The reason for the change of terminology to "salt spreading".
In answer to your e-mail I am able to provide the following response;
In the United Kingdom, salt (sodium chloride) is specified for general use as a de-icing agent on highways. In the past, grit (sand and small stones) was sometimes spread on roads to give vehicles a better grip on snowy or icy surfaces. The crushed rock salt that we now use is still routinely described as ‘grit’, and our winter fleet as ‘gritters’. Although commonly used, those terms are inaccurate, hence the change of terminology.
Should you have any further questions about the above issue or any other Highways Agency related issues please contact us via e-mail or telephone on 0845 7 50 40 30.
Yours sincerely.
Iain Ross
Tel: 08457 50 40 30
E-mail: [email protected]
..I don't need new wipers btw, I bought some from another website a couple of months ago, I was just curious as to weather you did them since I found them so hard to find in the usual places.
