- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys, we have great pricing on the latest 850w XFX Power Supply with SLI/Crossfire support. This PSU provides a super high-powered +12 Volt single rail which is ideal for overclocking and gaming.
XFX 850w Black Edition Modular Power Supply @ £124.98 inc VAT
The XFX Black Edition 850 watt modular power supply gives you the power you need with a brilliant combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 850W of continuous power at 50°C
- 80 Plus Silver Rating
- SLI Ready
- Detachable Modular Cables
- High quality Japanese brand capacitors (105°C)
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 70A/840W)
- DC to DC Voltage Regulator modules for +3.3V and +5V
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic cards (SLI & CrossFire)
- Active Power Factor Correction
- 5-year Limited Warranty
Only £124.98 inc VAT.
ORDER NOW
- SLI Ready
ORDER NOW
