Hi,
I am attempting to make my HTPC as silent as possible, current spec is:
Silverstone LC17 HTPC Case
ASUS M3N78 PRO with Athlon X2 5200
Thermaltake TR2-550 PSU
2x Generic 250GB SATA HDD's (not too bothered by the HDD noise)
Basically its the whirring of the fans I can hear and my PC is in an alcove which probably is amplifying the noise.
So today I have replaced the stock AMD cooler with a Zalman CNPS8700-NT, and the two rear 80mm exhaust fans with 2x Sharkoon Silent Eagle 2000's.
As there is only 1 Chassis fan header on the m/b the 2nd fan is connected to the power fan header (my PSU does not have a PWM lead), fan 1 is running at @1100rpm and fan 2 at 2000rpm.
CPU fan is running at 1100rpm.
Unfortunately the whirring is still there
(maybe a tiny bit quieter).
I have set Asus Q-Fan to Enabled in the BIOS and selected the Silent profile for CPU and Chassis Fans.
I'm wondering if it could be my PSU fan that is making the noise...
I've also seen the Akasa 3x fan splitter cable so might have a go with one of those... - http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK
Cheers
(maybe a tiny bit quieter).I have set Asus Q-Fan to Enabled in the BIOS and selected the Silent profile for CPU and Chassis Fans.
Cheers
