Focus just lost all gears.. whats wrong?
31 Jul 2004
Surrey
Basically just popped out and I was going round a roundabout and noticed the car felt odd.
Tried to pull away and realised I had no gears at all.
So when I'd pulled over I tested all the gears, it will full engage in all gears without any resistance or noise.
Still runs, revs fine and there was no suggestion this was going to happen, its never slipped in gear, I don't hoon it or anything..
56 plate standard focus st with 78k motorway miles on it..
My gut is telling me the clutch cable has gone because I had a 205 that did just this.. would I be right in thinking such a sudden loss of everything with no noise, knocking etc etc would point to that?
and if so.. how big a job is that?
If the clutch cable had indeed gone, then you'd notice it feel different when depressing it?
If It goes into gear.. without you pressing the clutch then something sounds a bit odd..
If you can get the lever all the way home in the gears with the engine on then the clutch cable hasn't snapped (although I'd be shocked if such a modern car didn't have a hydraulic actuated clutch).
well it seems that the clutch is permanently dissengauged which doesnt normally happen. They normally fail engaged.
no no, off to tremona I go if I get my way.
I only really HAVE to have it back by thursday. Thats when I'm going to start killing stuff if I don't have it.
no need for that mate I was asking a question.. I had a clutch die on me on an old car many years ago and I know what a slipping clutch feels like. I also annoy myself with how much I notice every squeak and vibration in the steering wheel etc.. I also know I do way too many miles to hammer my car because you just can't drive like that all the time.
Something could clearly have been on the verge of failure as its now failed but it certainly wasn't a clutch due to wear and tear... a clutch cable or however a hydraulic one works could have been on the brink, it was literally like turning the clutch switch off... one minute gears, all feels like it always did.. next minute I'm almost bringing a lung up pushing it into waitrose's car park.
Good job mrs100 works there and can swing me not getting a ticket.
Sounds very much like you have done a driveshaft.
You can get gears but you can't get drive so it's either a driveshaft/cv joint or the diff I would say.
