**OcUK Crysis 1680x1050 VERY HIGH Settings Top List**
I just got 34fps using only one my GTX 275 cards...
Am Going try testing with SLI enabled in a minute.. ;)
Am only getting 44fps using two GTX 275's in SLI in windows 7 with 191.07 drivers :(
I may install vista later and see if it makes any difference..
(re)downloading - could take some time with my connection :|
I did try this a while ago with my 4870x2(s) but it kept crashing out so deleted it - hopefully it will fair better with the 5870s
Overclocked GPUs
64.935FPS
And overclocked with 8xAA
56.865FPS
Interesting: I can see an impact of the AA there so it Looks like I am CPU limited in http://forums.overclockers.co.uk/showpost.php?p=15756430&postcount=590 ! The difference on mine between 0xAA & 2XAA @ 1680x1050 is 2fps and then no reduction for 4xAA & 8xAA! Similar for 1920x1080 ... I also noticed after that test that putting the 8800GT in there (to test PhysX) dropped the 5870 lane to 8x from 16x which lost me 2 fps apparently, just tried without the 8800GT and got those 2fps back :D But, tis moot at that performance anyways .. I'll leave the 8800GT in there as Batman looks much better (however for Batman AA my FPS goes from an average 306 to 109 but I can live with that lol :eek:) I see that you have one @ PCIe 8x also ..
Can you try yours @ 1920x1080, 8xAA ??
