If you use Internet Explorer the protected mode is a decent advanatge over XP web browsing. Although I've not used Firefox for years and the plethora of addons available.
I went from XP to Vista. Didn't notice any difference for a while then went back to XP it was slow, often stuttered, and just felt old. I still use XP on an old system but hate using it.
It's half the reason Vista/W7 are so damn fast.
Superfetch? Yes please, I'll have that too.
It looks nice with all the fade stuff and preview windows when you move over a taskbar item. (I would personally love to turn all this gimmicky crap off)
you can get ie8 on winxp aswell, so web browsing is no diff then on win7
Taskbar previews aren't exclusively for people with memory loss - that's a silly comment to make, disastrous even!
Taskbar previews goes hand in hand with productivity, it decreases time taken to minimise/maximise grouped windows and adds to this efficiency because you can simply middle click a preview box to instantly close it or click the icon thumb to open a new process of that application (or explorer window if it's explorer/browser).
I think people aren't actually looking at the benefits of such a new taskbar system like on 7 and instantly dismissing it as a gimmick when it clearly is much more which is pretty obvious to those who have actually read about it and used it.
It's not gimmicky at all, use to pin files etc. it is extremely powerful and useful once you start using it properly. it's just people say, ohh I got on fine with xp system, why do I need it. use it for a few weeks and you wont want to go back. it makes life so much easier.
Very few people need to (or should) open documents and applications en masse, fewer still so many that they need to manage them in groups. Even if their machine has the resources to do so. From what I can see people seem to always need to hunt through their "groups" to find what they are looking. Productivity boon it isn't.
With a high res monitor and multiple screens if you run out of space on the task bar for apps and docs, what are you doing? Doesn't make sense on a smaller screen either as it will be less powerful PC/laptop.
I don't see how pinning is much different than dropping shortcuts where you want them.
Now I don't think you've re-built your daily workflow around the new OS hence your negative opinion of it,
.I'd disagree, this is the OcUK forums where we have 8GB of RAM and big 24" screens so making use of what we have is the most logical and optimal way to compute on a daily basis.
I have multiple applications/documents open all the time and i will use them throughout the day and close them off once I am done with them. Below is a video to demonstrate this that I have recorded quickly just to show how easy it is using the middle mouse button and taskbar previews to navigate applications and documents - something ALT+TAB or window minimising and maximising would not be as swift at.
Sure, for the "average" user it might be a bit much but we're not average users here, we're gamers and power users and our collective system specs show this, our systems are fast enough to be able to handle leaving documents and applications open in the new taskbar without a performance hit and it simply means we can return to them throughout the day in bitesize chunks when needed and close them off at the end of the night when they're done with.
Now I don't think you've re-built your daily workflow around the new OS hence your negative opinion of it, that's fine, it takes different lengths of time to adapt for different people but I find it easy to adapt to new things quite quickly and as I hope my reply and video show, it is more convenient and logical to make the most of your hardware and OS features and spreading out the two over a convenient daily routine.
I still use XP and only have 2GB of RAM ... I feel quite inadequate now![]()
Since when has Aero Glass been "gimmicky"?
It's half the reason Vista/W7 are so damn fast. GPU accelerated desktop (with nice animations and transitions for absolutely free, zero cost)? Yes please.
The OP sounds like one of those "thinks he knows it all but doesn't" types. Hope I'm wrong![]()
