My fully watercooled pc - Build video
What were the fans? I think they said sanyo, but couldn't really make them out. Can you fit a shroud?
Missing motherboard, ram, hard drives and psu before it's "fully" watercooled by my definition, but a very tidy build and well shot video. Possibly more, at least a few other things probably give out heat.
You leak tested and flushed the radiator, right?
Nice computer you've got there.
When idle it said 200x20 (4GHz)
then when full load it said 195x20 (3.9GHz)
Then at the end it said 4.1GHz. :confused:
Nice setup none the less, must cruise through pretty much anything you throw at it I bet. :cool:
O yes! The benchmarks are all at 4.1ghz, the cpu temps at 4ghz was before i deed the gpus to the loop. Then i put down to 3.9ghz becuase 4ghz needed almost 1.4v
Nice... I really must try my hand at WC'ing
Hmmmmmm next build or this one?
Great work and vid. I wanted to see more of the actual doing though... the getting the watercoolers on the gcards, the pipe setup etc. It ended abruptly with pictures. Ohter than that, well done
Servo Gentle Tyhoon 1850rpm, dont really need a shroud becuase the curved blades gives a lot of airflow in the middle.
Ye, took longer than i thought so my mate walked off with the hd camera!
