- 13 Jan 2004
- UK
Noticed some people and specs saying that the 2209WA can run at 75hz at 1680x1050 - anyone know how? Reason I ask is that on my Windows 7 Machine I'm only able to get the usual 60hz!
This screen can actually do 75Hz without skipping frames, but it seems you'll have do a bit of fiddling with a custom timing setting to get it to work. If you've ever used you own modes in an custom x.config you'll know what it's all about.
Setup (with nVidia drivers. may have to use powerstrip or something similar to set up a custom mode with ATi, google it):
http://www.hardforum.com/showpost.php?p=1033914398&postcount=897
Confirmation that it is real, no frame skipping:
http://www.hardforum.com/showthread.php?t=1387587&page=64#1263
This and the new NEC 23" are the only non-120Hz that I've heard of that can do do non 60Hz-modes (in case of the NEC, up to 1920x1080@83Hz, but it takes DP due to bandwith needed. Have a search over at [H], should give you some pointers).
