Respray
Caporegime
25 Jul 2003
FR+UK
Am I being ludicrous and off my rocker by thinking I could attempt this myself?
I've sanded down and treated (Hammerited) some rust areas in the wheel arches on my MX-5 this weekend, and there are general patches where she's looking a bit tired; with a couple more rust patches to do this weekend. And on Sunday some cretin kicked my driver side mirror off (and left muddy foot prints on the door) so I will need to replace that, obviously the colour won't match 100%.
Should I just be realistic and pay for someone to do it?
What colour is the MX5?
I sprayed and fitted the sports sideskirts on my 5, finish and colour was 100% OEM, very happy with the results, so it can be done at home.
Used Halfords rattlecans too!
It's black, which I understand are notoriously difficult to match, but I'm not unhappy about the idea of changing it. I quite want to get some new seats as well (thats on the wish list for a few months in the future though), so might consider a new colour.
If it's just a mirror it shouldn't be a massive challenge to do it yourself. Depending on the colour it shouldn't be a terrible match depending on where you get it mixed.
If it's the whole car then it's a different matter. It can be done as a DIY job but unless you've got a lot of time to spare and you're very patient I'd just leave it to a good bodyshop.
If you can store it and afford the time to do it, I don't see why not if you're not expecting perfection. If you foxtrot it up though, it'll cost you to do it properly (or just hide the pain with satin/matte black). It probably won't bode too well for resale either.
£800-1000 will get you a same colour spray at a reputable body shop. At least that's what I've been quotes so far.
It's small patches at present. The mirror, wheel arches, and a few patches at the door sills. I'm not convinced I could get the matching right, let alone the finish to look like it wasn't painted by me :p.
In which case bodyshop it. There's nothing worse than attempting to do patches all over the place with rattle cans :(
I'll vouch for this, it looked spot on. The key is preparation and taking your time, never EVER rush a spray job.
Seeing as you're a "I haven't done that before, but fancy giving it a crack" kinda chap why not buy a compressor and a gun off eBay then get a bodyshop to mix you up your paint scheme, buy some decent laquer from them too (not forgetting a decent mask!!).
Couple of space heaters and some dust sheeting and you can make a booth in a garage easy. Throw some water down on the floor to minimise dust kick up, and you've got yourself a ghetto bodyshop in your own home. :)
edit - alternatively, I know someone in the South if you want a body shop. Drop me a mail in trust.
Do you know of any reputable bodyshops Dup? I'm searching for quotes online and not having much luck.
I got a quote from Painter Dave on the Nutz forum (which is down at the moment). He's in Yorkshire though. I also have a place nearby called Gaskell motor bodies (http://www.gaskellmotorbodies.com) who gave a similar cost and are round the corner from me. They did this unseen. Dunno about Cambridge but yell.com might help.
