http://forums.amd.com/game/messageview.cfm?catid=260&threadid=120655 seems that a few are having the same problem, is there an onboard VGA ?
450 watt is pretty low, try a higher PSU
500 watt is the minimum.
this is nonsense, sorry.
Urm No
http://www.guru3d.com/article/radeon...review-test/11
Quote:
Radeon HD 5770 (single GPU)
The card requires you to have a 500 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 40 Amps available on the +12 volts rails.
Quote:
There are many good PSUs out there, please do have a look at our many PSU reviews as we have loads of recommended PSUs for you to check out in there. What would happen if your PSU can't cope with the load?:
bad 3D performance
crashing games
spontaneous reset or imminent shutdown of the PC
freezing during gameplay
PSU overload can cause it to break down
An obvious thing but easily overlooked, have you connected the 2nd half of the power supply plug ?, it's easy to overlook when pushing a six pin connector into an 8 pin hole. PSU plugs are split to accomodate both 6 and 8 pins cards
ok try using the VGA boot,
Urm No
bad 3D performance
crashing games
have you updated your mobo bios? also there is a slight delay of up to 30secs when first loading post screen
