Which RAM for i5 build?
13 Mar 2006
Hello all, please can you give me some advice about what RAM to get to go with overclocking an EVGA classified and i5 750: I was thinking of either
Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel (PGV34G2000ELK) [PGV34G2000ELK] £115.98
or
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-16000 2000MHz Dual Channel + 3D Mark Vantage (PVV34G2000LLKB) [PVV34G2000LLKB] £121.99
or
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) [PVV34G1600LLKB] - 7-7-7-20 @1600mhz £82.76
or
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMD4GX3M2A1600C8) [CMD4GX3M2A1600C8] 8-8-8-24 @1600mhz £132.99
Am I missing something - seems like the Patriot sector 5 1600mhz 7-7-7--20 stuff is the best value and ample for overclocking headroom - am I likely to be limited by any of these kits overclocking-wise? I was under the impression that 1600mhz memory is more than enough headroom for overclocking. They'll be passively cooled in a zero-fan, open-sided case (see my sig) - anyone think there'll be heat issues?
Is it worth going for some of the more expensive kits - am I likely to see much difference, or are they just for people with money to burn?
Youve caught my eye with that 7-7-7-20 patriot at £82, I was about to order the XMS3 on this week only at 85 but the better timings for slightly less money is pretty tempting. I would be interested in any experiences anyone has too.
Went for the Patriot 2000mhz 8-8-8-24 for £123 in the end. Seem to get to around 2130mhz ish at stock volts and 8-8-8-24 from the reviews I was reading. Hope the heatspreaders work okay - not going to have any fans on them, or in the case for that matter...
Do they seem ok quality wise? I think i might go for the 7-7-7-20s above as I'm not going to want to push it past 1600MHz
I'm also deciding what ram to go for with i5 at the moment. I was definitely going to get this (when it comes in stock..)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-037-GS
But the i5 only supports up to 1333mhz? This ram does 2000 at 1.65 volts, which is fine for intel's spec, but would I have to do some serious ram overclocking to get to 2000mhz? Is it even possible?
If not, the patriot sector 5 looks great. Am I right in thinking the Viper II is better than the G series, as the latency is 7-7-7-20 rather than 9-9-9-24?
Personally id go for this stuff G.Skill DDR3 PC3-12800 ECO Series if your motherboard is on G.Skills aproved list, runs cooler then most memory, and also overclocks extremly well too
I ended up going for this :)
Hopefully it'll be allright. I'm most worried about the elevated Ramsinks getting in the way of my cooler :p
EDIT: Apparently my order hasn't been shipped because the ram is out of stock, despite it stil saying there's 10+... Going to change it to the Corsair, unless there's something better for the price. The Corsair will be fine with i5 right?
Memory controller runs at the CPU base clock (= FSB) frequency.
i5 runs at 133MHz (x20 CPU multiplier = 2.66GHz), and has memory multipliers x6, x8, x10. Therefore max memory speed is 133 x 10 = 1333MHz. Core i7 has additional x12 memory multiplier so supports 1600MHz.
However, CPU base clock can be increased: if you get an i5 up to 200MHz, memory will run at maximum 200 x 10 = 2000MHz.
Quite a few people seem to run the Core i5 at 160 x 16 (= 2.56GHz) to run memory at 1600MHz. Although the CPU isn't 'overclocked' as such, the base clock frequency obviously is.
Thanks. If my i5 is overclocked to 4ghz, what is the lowest speed the RAM can possibly be?
Whatever your base clock is, x6. At 200Mhz x 20 (= 4GHz) for instance, slowest memory would be 200 x 6 = 1200 MHz. I would imagine you'll hit the CPU limit before getting too fast for the memory.
I can't really say as I've never tried overclocking my computer, or have any need for it as everything runs just fine for me.
Thanks :) Yeah, I just wanted to check that it didn't go above 1600 as I'm never too keen on overclocking the ram for a few reasons.
Having looked into it further it appears the Patriot ram isn't really 7-7-7-20 , those specs are its secondary XMP profile which requires 1.9v. At the normal 1.65v its 8-8-8-24 which is a little less impressive.
That's actually a bit of a relief! The Corsair I changed to was a few quid more expensive and I was thinking that I paid more for less, but tbh, I'd much rather have Corsair with a normal sized ramsink which is 9-9-9-24 than patriot with the stupid elevated one at 8-8-8-24.
I got the Corsair on 'This Week Specials' for a new i5 build which I have just finished. All running at stock, not bothering even trying to overclock, running sweet and cool with stock cooler on i5 750 :D
Pretty shameful to advertise the Patriot Ram at 1600MHz 7-7-7-20 when you can't acheive this without over-volting the P55/core system. They should advertise the 8-8-8-24 @1.65V, and 7-7-7-20 @1.9V as seperate XMP profiles :(
