Modem/router with IP reservation...
27 Feb 2006
Lincolnshire
Hi, can anyone suggest a make/model for the above so I can make reservations to mac addresses on printers connected to a workgroup?
Cheers,
Chris
Hi, thanks for your reply, you would have thought a 'half decent' modem router, not just a router, would be able to do, however my Linksys wag320n will not...
Chris
I use a cheap WRT54GL running the Tomato firmware to do this..
This is just a router, so a do use an old DG834N for modem duties (running DG Team firmware for tweakability)..
Chris
Says summit about your router then eh
Netgear dg834 does
