I just use a beard trimmer with the guard off every few days, only takes a minute. Best £7 I ever spent![]()
If you really wanted an inexpensive shave you'd be better getting a DE safety razor and blades. Get a pack of 100 actually sharp blades for a tenner.
thanks for the tip i will give it a go
I tried one of those for a while, couldn't get on with it, seemed impossible to get the hairs close to the bottom of your nose
What the hell? You can use the same razor for 2 weeks?
I use 1 per shave! After using it once, even after cleaning it, it just hurts!
