The Sunbeam Core Contact Freezer comes with a control panel.
The instructions don't make it clear how to connect this.
The fan has a 3-pin plug and this obviously plugs into the 3-pin socket on the panel.
This leave a 3 pin plug on the panel. This can only plug into a 3 pin fan socket on the MoBo.
So do I plug this into the CPU fan socket on the MoBo - obvious I guess but what puzzles me is isn't the voltage on this MoBo socket varied depending on the CPU temp.
If it is then the speed is being modified twice - once by the MoBo and once by the panel so how can you be sure what you will get.
Or should I use one of the system fan sockets?
I've visited the website but this just repeats the in-box instructions which don't help much.
Cheers,
Nigel
Cheers,
Nigel
