Incorrect voltages are shown
Hardware sensor chips are generic devices that can be used to measure voltages from anywhere. The measured voltage must be converted to the range required by the sensor chip. Standard monitoring chips specify which external circuitry must be used in order to measure voltages outside some range. Voltages like 12V, -5V, -12V and some others need this external circuitry. Some manufacturers chose not to follow datasheets. If this is your case, then you will read unusual values from SpeedFan. Since this custom circuitry is not known, SpeedFan does not try to "guess" it as any reading wouldn't be safe. If you get really odd voltage readings, simply enter configuration and uncheck the relevant ones.
