Logitech G35s: opinions, alternatives?
3 Jun 2005
I am about to buy a pair of the G35s, but thought I'd check with you lot first.
What do you think of them? Any alternatives I should look into?
The headphones will be used for gaming and vent.
getting a set of these with my new build, so interested to hear back too, altho all the reviews I have read say they are very good
If you have a decent soundcard; xifi gamer etc... I would get the Razer chrcharias (called somthing like tht :p)
Crackign headset, they are better than the g35's imo.
Never really liked 'gaming headsets'. Why don't you try a decent headset, i.e Sennheiser 555's, goldring 150's etc. Then add a clip-on mic, zalman/elara seem to be popular, en voila.
Each to their own though, just another option for you to think over.
cause we have all had our heads turned by the built in voice morpher and wanna pretend to be darth vader/kidnappers/spys on ventrillo :p
