- 11 May 2006
I was a little suprised that there's been very little discussion about the image quality on these cards so I decided to do some looking around and found this article:
http://alienbabeltech.com/main/?p=12648&page=2
There clearly seems to be an issue with the anisotropic filtering on these cards where texture detail drops off at distant angled surfaces, eventually leading to deadzones with no definition at all. I tried this myself on my HD5870 (Catalyst 9.12) using D3D AF-Tester (download) and this is what I got:
The article goes on to show actual in game comparisions, where the effect is a lot less pronounced but still noticeable in certain situations.
Personally, I'm not too concerned as I doubt I'll ever notice it in games and certainly, image quality seems just as good as it did on my HD4890, but it is still a little worrying that this wasn't picked up by ATI before and that it hasn't been discussed by any of the major reviews sites.
I just hope that it's not something that's hardcoded into the hardware, but fixable via driver update. Would also be useful if more people tested this, on different cards and raised the issue on the ATI support webpage.
HD4850 AF:
GTX285 AF:
HD5770 AF:
... Moving on to the 5770, we see something bizarre happen. It introduces sharp gray transitions of varying texture detail, eventually culminating into what can be called a “dead-zone” – the solid gray ring touching the outer red section with no discernable texture pattern applied to it. Furthermore, the largest gray ring introduces new stars that the other two cards don’t have (two such instances are marked with white arrows).
