Carn't log into steam, just me?
30 Sep 2009
I am meaning the log in on the website not logging into the actual client but i cannot log in on the website atall it just loads and loads and eventually times out after about half an hour:confused:. Ive tried different computers/browers to no avail. Anyone else having this problem? is it me or something to do with steam?
Maybe try on another (trusted) computer with a different internet connection. At least this should tell if its routing problems or your account............
Alternate if you know how to use it, try logging on via Tor.
That is weird - but hence my suggestion of using Tor or (reputable) proxy servers but ONLY if you know what you are doing..........
It not possible for me to be able to buy through the steam client...
I have to use there website..
This is the reply i got from steam support when i e-mail them about not being able to pay for any games through the steam client..
Hello,
A staff member has replied to your question:
Hello Mark, Our records are showing the purchases are still mainly failing due to the same issue. Please ensure to use an external browser and not Steam to attempt the purchase using the link below: http://store.steampowered.com/?cc=gb You will be unable to use the Steam client to make the purchase as you cannot edit the URL in the client, only in a web browser is this possible.
It is true, the client does use the Internet Explorer ActiveX control.
But there's nothing to be paranoid about, in order for IE to be a security vulnerability you actually need to visit a website that exploits those vulnerabilities. Since the Steam Client doesn't allow you to type a URL in and restricts it to Steam pages, there's no issue?
I thought it did use IE, but like i said the client won't work either so it doesn't really matter:P
Wtf I just logged in using another internet connection fine so i was thinking it must be my connection, tried mine again after this and it works?! god knows how that works but its working so i guess I shouldn't complain.
