stofens are a bit rubbish, lightspheres are DEFINITELY the way forward!
http://twilight-photography.co.uk/v1site_images/galleries/gallery3/TWP_3063.jpg[img]
Completely dark room, on camera lightsphere and a 580exmk2 with another lightsphere held in my left hand at half reach....[/QUOTE]
I wouldn't go as far as saying the Stofen are rubbish. They are very useful for a small little plastic but I totally agree, Lightsphere is the way forward - if only they weren't so big. Especially when positioned properly, you'll have a lot less underexposure under the chin and (deeper) eye sockets for indoor portraits. That Amber dome is also very useful for adding some warmth.
[quote="ScarySquirrel, post: 15828711"]Is this what you're all talking about? - [url]http://www.surreyphotographyshop.co.uk/images/Sto-Fen-Omnibounce.jpg[/url]
I got something similar from eBay for about £2 or something.[/QUOTE]
That is indeed.
I know the genuine version works a marvel, not sure of cheapo version - they might work just as well, not tested any before. I did do a test between a proper Lightsphere and a Chinese knock off. Nothing close in terms of build quality and effect though (stiff plastic and the flashgun have to work harder for the same exposure and softening of light.)
