Find me this specific pressure washer
1 Dec 2006
Amsterdam, NL
One that does NOT rely on a hose or a constant water source. I need to find a independent pressure washer that I can move about and just fill up with water.
Power supply is not an issue...
Any idea?
ags
Aye, but a 'home' size lol.
Is it not possible then? To get one with a container and just fill it up when needs be?
ags
ags
Problem is how fast it would run out of water. Running "dry" damages pressure washers.
Even the smallest ones use about 5l a minute and nobody would buy one with just a 5l tank on and hence one minutes use.
Also because you want a pressure washer with it's own water supply, the tendancy is for it have a diesel or petrol engine so you are not dependant on a power source either so it can be used anywhere.
Motorised pressure washers are much more expensive and tend to be bigger/more industrial and not designed for home use.
The Karcher is probably the closest you will get but at £2000 it ain't cheap!
Surely cheaper to have a hose pipe????? :p
The alternative would be to buy a normal pressure washer which could be run from a tank (doesn't need mains pressure water) and buy a water container.
Seems so lol, it is one of many little projects I have to do... Just avoiding it is all.
Oh well, cheers for the help guys
ags
I say I deal with Karcher but in reality I only deal with the MD and Head of Direct Sales ;)
I do both of thier cars on a 2 for a Tenner deal
