same here, 3.8 is the highest i can get prime stable unlocked as a quad, thats with watercooling as well, excess voltage doesnt seem to help either, keeping it as cool as possible seems to make a much bigger difference.
the mobo temp sensor at idel reads around 21, after a good stress test it reaches 32. im using a simple swiftech h20 220 watercooling setup, only cost me 30 odd quid off an auction site lol, seems to cope with everything thrown at it![]()
on another note, the swiftech h20 setup is great for an introduction to watercooling, works very well and if you can pick one up cheap a great addition, the radbox is a great idea as well so you can mount the radiator on the rear of the case if you dont have a case made for WC.dont forget real core temps are around 7-10 degrees higher than the reported temps.![]()
Do you mean higher than the mobo sensor or higher than the core sensor?
I have found that the temps on the core are generally 5-7 less than on the mobo.
The K10 platform (Phenom, Phenom 2, Athlon 2) core temp sensors are not accurate, the motherboard sensor is much closer to the real temp and that in itself is likely to be off (under) by a few degrees.
If you're measuring by the k10 sensor, then your processor is too hot. Hence the "I put more voltage (read: more waste heat) through it and it becomes more unstable"
I'm not sure what you mean. Is your vcore set to auto or not? If it is, then how are you manually raising it?
EDIT: just noticed... replying to two people thinking they are the same! (sorry!)
