On the topic of ST220 brakes, I've found mine to be a bit soft too. The braking ability is there, just you need to press the pedal a lot more to use it, you get used to it though. Maybe braided lines will make a difference...
Apart from that, its a very capable car - if you're after a smooth motorway cruiser, coupled with some fun on the back roads, you could do a lot worse. Sure, it drinks a bit, and could do with loosing a bit of weight (couldn't we all!) - makes a lovely noise too! At the moment I can't think of what extra I'd want from my next machine...
