£180 max could sum1 spec me a monitor
Any chance i could get a link?
we are not allowed to use competitors links, but a quick google will take you to the correct page on dells site.
Although it has just gone back to a higher price, it's been £175 for the first few weeks of 2010 and then up to £186. It is now at £216, which is why I suggested if you were interested to wait...
OH and its higher than HD res (2048x1152) comes with a built in 2MP web cam, stereo microphones and a 4 port usb hub. Has DVI. HDMI and VGA inputs.
And although it's a TN panel (Samsung panel) it is, imho, stunning.
Hmmm sounds good thanks a lot mate!
Had mine for about 6 months now and I am very happy with it!
Oh I forgot if it makes any difference it also supports 1:1 pixel mapping
Teddy what about this one, i am kinda in a bit of a rush for a new monitor. I've read that the contrast is actually 50000:1
http://www.overclockers.co.uk/showproduct.php?prodid=MO-075-LG&groupid=17&catid=949&subcat= <---- ignore its the step up:
found it for £148
here is the spec:
Boost your level of entertainment with the LG W2261VP-PF! This TFT screen is ideal for film fans and gamers, as it boasts a 16:9 aspect ratio, Full HD resolution and an incredible contrast ratio of 20,000:1 for deep blacks and vibrant colours. The W2261VP-PF also has a response time of 2ms and a host of connectors, including an HDMi socket for hooking up a games console or digital camcorder and instantly enjoying your multimedia in high definition.
W2261VP-PF 22" wide TFT Screen (2ms) 2 ms, DVI,
50,000:1 for High HD capability
2ms response time (grey-to-grey)
High resolution: 1920 x 1080
D-sub, DVI-D and HDMI input
300 cd/m2 brightness
Technical Details
Size - 22" Class (21.5" Diagonal)
Brightness - 300 cd/m2 (Typical)
Contrast Ratio - 50,000:1 (DFC*)
Viewing Angle - H : 170°, V : 160° (CR>10)
Response Time - 5ms (GTG)
Supported Colours - 16.7M Colours
Resolution - 1920 x 1080
Connector - D-Sub, DVI-D, HDMI
Power Supply - 100~240V (56~75 Hz), LIPS (Integrated)
Dimension (W x D x H) - 519 x 193.2 x 387 (with stand)
Weight - 4.2kg (with stand)
Multimedia - FLATRON f EngineTM
Stand - Tilt angle 5° front, 17° rear
