Noctua NH-U12P
29 Jun 2009
London
Hi Guys,
Can someone help me I have originally brought this with the Core i7 OC bundle. However I would like to use this cooler for my brothers Asus P5KC Motherboard and Q6600 CPU.
The LGA1366 bracket is bigger and the holes on the motherboard do not match up.
Can someone advise me what the correct mounting brackets and where I could buy this brackets in the UK.
Thanks in advanced.
Bashy.
I you have the new Noctua then the bracket can be used on Socket 775, 1156 & 1366 but if you the older one, then it only fits the 1366 socket.
Thanks Reygjabla. I had purchased the cooler in September 2008, as I have the LGA1366 bracket.
Bashy.
