i3 530 the "clear choice" over Athlon II
Caporegime
17 Feb 2006
Cornwall
...for gamers. That is the assumption. Let's try to see if the facts support this statement. I want to look at the x3 435 as the competing chip in this thread.
The i3 530 currently retails for £90 upwards.
The x3 435 ~£55 upwards.
The i3 motherboard typically starts at £70, am3 starts at £45 or less.
Firstly, using Anand's bench tool, here are some results:
(FPS) Dragon Age:Oirigins: 435=91, i3=94.9
Fallout 3: 435=79, i3=69
FarCry2: 435=40, i3=47
Crysis:Warhead: 435=69, i3=77
Dawn of War 2: 435=42, i3=52
(WoW FRAPS recording: 435=63, i3=75)
Left4Dead: 435=97, i3=108
Clearly, the i3 is the better chip. It uses much less power, gives a handful of extra FPS in games, but is also better in the synthetic tests and non-gaming apps. That isn't being disputed here.
What's interesting is that in all benchmarks above, when either processor managed 60FPS, both did. In FC2 and DAW2, both fell below 60FPS. in 5 of the 7 games shown, both achieved a playable frame rate of at least 60FPS.
I personally think that to be the "clear choice" above the Athlon x3, the i3 must have a much stronger benchmark result. There have to be lots of games where the i3 manages 60FPS and the x3 435 simply can't.
Why? I don't think the difference between 69 and 77 FPS is meaningful, or between 63 and 75, and definately not between 97 and 108. They are all very playable. In fact, we can afford to turn up the visual quality settings, placing more strain on the GPU, and reducing the difference between the CPUs to almost nothing.
So here's the challenge! Let's find benchmarks where the i3 dominates the x3 435 is games, reaching 60FPS at least and leaving the x3 below 50FPS. Even if we compare an overclocked i3 to a stock 435, can we find such a result? And can we consistantly find this result in many games?
(To makes this a meaningful test I'm going to disqualify benchmarks using resolutions lower than 1280x1024. This is not a pure CPU test).
To me, it seems you might as well be comparing the 285 to the 5870.
You are comparing components from current gen and last gen.
AMD have not released their new chips yet.
Intel would really have cocked up if their new chips didn't beat AMD's old ones!
No, it's a question of "good enough" not "best of the best".
To me, it looks like the 435, at nearly half the cost of the i3, is "good enough" for gamers.
The point of this thread is to give the i3 advocates a chance to prove that the i3 is the right choice, and a "clear winner" over the Athlon II chips, when gaming.
but surely when new games come out they will be optimized for newer technology, so the chances are when some games start to come out end of the year, beggining of 2011, i would imagine they will work better on the newer i3/i5 and amds.
how many games are currently optimized for QC? very few in reality, so most DC 775s would be as good as the QCs, does this mean that in the future it will stay this way?
Nice thread. I am really interested in seeing the results as i believe that the Tri-Core offers some tremendous value for the price that it retails.
I am assuming that we are measuring stock performance here though? and not overclocked?
Paradisiac: Thats debatable. Hyper threading is not the best solution for threaded apps though it certainly helps! Games will become more threaded and the AMD scales nearly linearly with good threaded applications. Hyper threading not so much. And the point here is "good enough" bang for your buck i think.
Should/could you not compare two rigs which cost the same?
I.e your AMD rig is 55+45 = 100, wheras I3 ~ 90+70 = £160??
Overclocked performance is valid, but I'd say keep to stock voltage and stock coolers if you're going to. Otherwise it's extra expense.
If overclocking adds game performance (it may not have much of an effect in some titles), then it's certainly a consideration.
The point of the thread is not "I'm spending £100, what should I get".
The thread is accurately called "Should I spend £100 when £55 will do?"
do both setups have the same features/capabilities?
are you getting exactly the same for £60 less?
point is, are those benchmarks on pcs with exactly the same spec pcs (ram, gfx....) just 1 has a £55 chip on a £45 mobo whilst the other one is a £90 chip on a £70 mobo?
Depends entirely which game you mean.
In games that don't take advantage of higher than dual core the i3 is going to win. In more multithreaded code the Athlon will put up a fight.
At a guess: Supreme Commander, Ghostbusters, GTAIV and Far Cry 2 (plus a handful of others) will do very well on the athlon. In future ports from the 360 and ps3 and other multithreaded games will do better on the athlon. For everything else there's i3.
Yeah but this thread isn't about which chip "wins". It's obvious that the i3 will win in most games.
But what's not obvious is how much that matters. When you're gaming at 1680x1050, with medium or better IQ setting; if both chips are giving you 60FPS, does a few extra FPS matter?
What I'm driving at, is how "necessary" an i3 is, for a gamer. Does the x3 435 "suffice"?
The Anand benchmarks gave me the impression that the x3 is a strong performer, and the benefit of going to the i3 might be marginal at best.
So I assume the snobs on here will also look down on people who have Intel E5000 series processors overclocked on cheap G31 and P31 motherboards then??
The same went with the E2000 and E4000 series chips.
In many forums the world over people were comparing them to the more expensive Intel chips especially in gaming too.
but going but that theory, the 775 chips will still 'suffice' for current games and can get them at the same price as the amd. not really seeing your point here :confused: do people not upgrade for the future, not the here and now, or even in some of the game choices benchmarked, the past??
Why don't you just let him do the comparison and we can decide from the findings!
I would also chuck in a similarly priced Intel Core2 combination and we can see how both fare against the Core i3.
Personally I upgrade when I feel that my PC is not up to the job any more. Others do it for fun. But really, most upgrade when they need to upgrade rather than to future proof. Technology moves so fast that it doesn't make sense to buy for the future if you don't need it in the present! In fact I am one of the people who believes that most 775 set ups are good enough really.
The only downside to 775 is the fact that its a dead platform with no upgrade path and usually the motherboards were more expensive as far as i recall. AMD does offer some excellent mobos for not a lot of money.
didnt mean future proof, but would be no point in upgrading to technology that will not be good enough for atleast a good year or so, so just because the amd will 'suffice' now does not mean come the end of 2010 that there wont be games out there it will struggle on. personally i think its down to personal preference, i would personally never buy an amd system, not because they are bad, just because i have had bad experiences with them and prefer intel stuff. and the same will go for people and amds.
