Well got it all hooked up PSU seems to be able to handle it fine. Not sure if i've installed everything properly, just had a run on crysis and tbh I wasn't that impressed. It is faster but not as fast as what I thought it would be. When outdoor it getting pretty much 30fps and goes up and down. When indoors it's getting about 50fps. It is a lot smoother and the image quality is a lot better but I expected more FPS. I don't know if i've done this right or where to check in CCC that both cards are running correctly. I also put on two crossfire cables from each 5870 as there was two bits for it, is that right or should i only use one ? Any help would be appreciated, thanks......
Got quite a few new system parts in transit soon, having to leave it up to a family member to answer the door
