GTX 295
Check the temps... I run 2x 200 series cards in SLI with barely a gap between them... and in what gap there is is where my Creative X-Fi has to go (only PCI slot) which chucks out a ton of heat itself... and I'm still getting decent temps with a single 120mm fan brining air to them directly.
well im not waiting.. plus its too late for that.. as i already have 2x5870's
and they are running sweeeeeeeeeeeeeeeeeeeeet
i only got the 1000w PSU because i was going to get some power hungry NV cards.
but im thinking its maybe a few watts too much for the ATi's, i mean there isnt the need to have so much
Supposed almost 2x the power of the current fastest Ati.. ?
No.
Yeah, you wont need 1000 watts. If you want to find out what it's using try entering all your system details intoPSU Calculator.
Lol Paul! I bet that guy really hated that comment. :p
Anyway back to your PSU question.
Yes it's a little overkill but not really that much so I think you should keep it for the following reasons.
1) A PSU is most efficient when at half or less it rated load, so this means your system will use even less power.
2) Should not have any issues with heat degrading the PSU.
3) Won't need to upgrade if you fancy going Fermi SLI in the future.
4) If you ever find your self on a mission for silence, you can swap out the fan for a low rpm fan safe in the knowledge that your PSU won't overheat.
5) You probably won't save that much, if you sell it and buy another PSU.
6) Lastly, 1000W is a nice round number! :o
Edit:
I don't regret getting a 1.5kw Toughpower, as I'v been able to swap out the fan, and it's just as silent as my 5870, and will handle anything I can throw at it in the future.
Note
It only cost me about £130 when the exchange rates were better.
That can't be right heh... but theres no harm having a bigger PSU than you need... as mentioned above running a PSU capable of providing a good margin above the power draw of your system means the PSU runs quieter, cooler and is under less stress. The PSU won't be running more than is needed it will only provide upto the power the system is trying to draw from it - not pumping out 1kw 24x7.
I personally wouldn't run a system like yours on anything less than a 750watt PSU.
thanks for the link...
:eek:... if i have done it right and this is right, the site says i only need a
425w!!
Yeh, I used that site before I got the Toughpower and blew up 2 PSU's ( One PSU took out my power on switch on my cosmos S).
The two most important areas to spend money on a PC is the Monitor and PSU because if you spend money here your not going to need to upgrade for years.
yeah its the thought of the power consumption that im thinking about.
quote "not pumping out 1kw 24x7" << is that true?
and when i ordered my parts in the first place, i had a 750w on my list, but OC informed me to up it to run the 2x295's ( which i didnt get in the end ).
The actual wattage in use will vary - but it will be under the rating for the PSU - depending on the system generally well below 200watt when idle and for the kinda system you have over 400watt under normal load conditions - bare in mind you will see peaks of around 150watt above that and you never ever want to run a PSU above 70% load for average models or 80% for high quality PSUs if you want a long lasting, stable system and I'd put 750watt as the minimum I'd use.
yet again great answers and replies.. thanks
i feel happier now... as i have to be honest i was worried that with the bigger PSU
that i would see a bigger electricity bill!
