Cat the FifthQuote:
Originally Posted by hitman View Post
Why do you think I should change my motherboard and hard drive - will the current ones not work with the 5850??]
DDR3 RAM does not fit a motherboard which uses DDR2. Look at the link to the Gigabyte webpage I put in my post!!
In the details about the motherboard it says the following:
"Dual Channel DDR2 1333+ MHz
Delivering native support for DDR2 memory up to 1333MHz, GIGABYTE Ultra Durable 3 motherboards allow users to easily reach higher memory frequencies at lower voltages; achieving higher memory performance with lower power consumption to run even the most memory intensive applications such as high-definition video and 3D games with ease.
* DDR2 1333+ is supported with combination of AM3 processors and qualified memory modules, please refer "Memory Support List" for detail memory support information."
The motherboard will take AM3 processors like the X4 955BE but does not use DDR3. The AM3 Phenom II processors have both DDR2 and DDR3 memory controllers in the CPU.
The two fastest 1TB hard drives are the Samsung F3 and the Western Digital Caviar Black.
CAT-THE-FIFTH is offline Report Post View trust for
I appreciate your reply and advice, but I think you've misunderstood my post as I've already bought these components and am running the DDR3 ram with this motherboard. If this is the case, then I assume it's okay to go ahead and order the 5850 graphics card with this system???
, runs great when crossfire is supported . back on topic =wait to see what the 5830 runs like
