You can stream Dolby Digital, DTS etc from the PC to amp. Your amp likely produces a better sound than your PC too.
decent surround ability, better quality sound fead. wortht he switch if you have the option.
Decent surround? You can't get surround from a stereo 3.5 jack.
It'd be surround, quality would be determined by the receiver and the attached speakers.
Technically you can get surround from movies and some games with a stereo 3.5jack, Its called Dolby Surround, or Dolby Prologic, and most movies still carry the dolby surround encoding within the mix, so that old school 5.1 recievers can still work.
Infact ProLogic 2 isnt half bad at what it does. Sure digital is better, but surround is surround![]()
what i meant was at the moment the 3.5mm jack is incapable of carrying a surround sound signal so is constrained to a 2.0 setu-up, using spdif to carry the signal instead would give him the ability to have a 5.1 set-up capable of delivering dts, dd, dolby true true hd etc. he asked if it was worth using spdif so i clearly stated what he could gain by using it, at the moment he doesnt even have the option for surround.
Prologic II is done by the receiver really, the feed going in to it is still stereo, still, good point though, prologic is most definitely better than bog standard stereo.![]()
Yep, tested it out with the Wii and Zelda a while back. Made me regret I hadn't done it sooner as it definately made the soundscape more immersive, even if the rear channel wasn't as detailed/clean as a dedicated surround kit.
Shame I'd already finished the game really, as it wasn't a bad sounding game as it stood.
Gotta be one of the things to like about Nintendo, despite any flaws, Nintendo 1st party titles are nearly always spot on technically with what the system can do at the time. Never tried the Gamecube with prologic, might just have to go check out Metroid Prime, Eternal Darkness and WW with it just to experience the games again, as I seem to remember they all had it.
I'd imagine when they transition Zelda to HD, with full surround sound etc, it'll be VERY well done, and nice to look at.
