I need a new case can someone advise to one?
Permabanned
19 Nov 2008
Peterborough, England
I'm going to water cooling and therefore want a larger case, I need to internally mount a double rad. I would like holes in the motherboard tray for cabling, a black paint interior and bottom mount PSU. I'm thinking of the Coolermaster HAF 932 but is a bit too much as i only really want to spend around £100. Thanks
Would downgrading to the Haf 922 not just be fine? I'm not sure of internal space but it seems barely smaller from the specs I've seen and bigger than the CM-690 too.
It's in stock and around £90 so in budget too.
Yeh but not enough room in the top Insanties_birth!
Ah okay then. Not sure which other case to recommend but if the cm-690 has the room like the previous commenter suggested it might be a good option.
This zalman case should fit it but can't be certain unfortunately.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-028-ZA&groupid=701&catid=7&subcat=
Advanced version is coming out of the cm-690 though if you can wait.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-196-CM&groupid=701&catid=7&subcat=29
i think you should save a bit more as the haf 932 is excellent for the reasons loads of space cable tydying is a dream and you can put your power supply top or bottom and also has cut outs for liqyid cooling if needed ....best case ive ever bought...it is big though in height.
