How can i find the distance(miles) between different airports ??
Caporegime
27 Nov 2005
Guernsey
Does anyone know how i can find out the distance(miles) between different airports ??
I.E
what would be the distance between guernsey airport and manchester airport by plane ??
(I don't have/own a paper map to measure the distance with a ruler..)
Road or as the crow flies?
Guernsey is an island.
;) jk
OP - google earth has a measure facility. you can click from point to point and it will give you a straight line distance, or you can click miltiple points and it will add them all up.
Thanks...:)
I have a look now..
Edit:Just had a look in google earth...Thanks again,That was just what i was looking for..:):):)
I can do this for £3000. :D
Ok then i pay you £3000 in cash....:)
Picture to prove that i do have the £3000 in cash to pay you..
Mr chaparral I am calling from your bank. It appears there is a slight problem with the monies in your account, they appear to be pink. In order to die them to the appropriate colour I need to ask you four your bank account noomber in order to remove the gay (pink) bank notes from your bank account.
thank you
Mr obamzusammbaooor.
First cowrearendmatter bank
Nigeria
260.3nm by air and this is the flightplan you'd take -
EGJB SKERY N862 BHD N864 MONTY EGCC
You'll probably be flying to Barton though if it's a private flight, so still about the same distance.
